Digital Mars C++ stlport and C++ bugs
ccfriend
    Oct 29, 2005#1
    Hi
    Recently I start to use UEStudio in my job. I try to use UEStudio with Digital Mars compiler and stlport addon for C++ programs ( For common C programs UEStudio works great )
    The Digital mars stlport help file says that you must use that in order to compile a C++ file ( this work great when I run it from command line )
    dmc hello -I\dm\stlport\stlport ( for hello.cpp file )
    I try to add -I\dm\stlport\stlport to compiler and link options but I have errors in compiling not founding libs of C++
    Can anyone help me ?
      Oct 30, 2005#2
      \dm\stlport\stlport seems to be a relative path specification to current working directory. So check the working path specification in UltraEdit or use an absolute path for -I option.
