How can I disable generation of makefile?
    Aug 08, 2007#1
    I configured UeStudio for compiling drivers from Microsoft DDK with BUILD utility. All working except Uestudio overwrites my own makefile and BUILD utility can not compile my project correctly.
    I did not know anything about Make utility from Microsoft DDK.
    In my opinion simply it has not own Make utility. And MAKEFILE must be created manually.
    How can i disable generation of makefile?
    Or tell me about better solve.
    P.S: Sorry for mistakes. English is not my native language
    6,663562
      Aug 08, 2007#2
      What happens when you simply set the read-only file attribute on your self-made makefile?
        Aug 08, 2007#3
        MyMake simply tells "Cannot save makefile" and build process will stop
        I found a solution. I rename my self-made makefile to the buildfile
        BUILD utility from Microsoft DDK call nmake utility for parsing my makefile. Nmake utility has key /fFileName in CommandLine. This key allow using different file than MakeFile.
        Now All work.
        It's interesting. I use UEStudio for 3 compilers: Fasm, VectorC86 and Microsoft DDK build. And all these compilers does not need makefile from MyMake utility from UEStudio.
        Really is it impossible to disable generation of makefile?
        6,663562
          Aug 08, 2007#4
          I think no, but I'm not an expert about the compiler settings. I have only found in help of UEStudio the page [General] Compiler Section (tab Contents - Compiler Configuration) where it is explained how to specify a different make tool.
          Best you ask IDM support per email to get a definite answer for
          Does a "Disable generation of makefile" setting exist?
            Aug 08, 2007#5
            Thanks a lot Mofi
