No. Most of the available configurations are made by users and send by email to IDM. I suggest you create a backup of all files in subdirectory "configs/Intel C++ Compiler", then open the files in UEStudio and adapt it to v10 of the compiler. When the adapted configs are working fine, send them to IDM by email.
I am new to UEStudio (but old user of UltraEdit), just downloaded it for a "test drive".
In the last few hours I started looking into the configuration syntax and the idea is getting clear.
I will try to create a configuration for ICL 10.0 and send it back to IDM.
Thanks for your advice !
Armando A B.
Do the same as armandoab for v10 according to my suggestions. Compilers are often very compatible to previous versions. So I think you have to change only a few entries in the existing configs for Intel C++ 7.1. I guess you have to adapt only Version = 70 at [Settings] referenced several times with $(Version) in the section [Environment] where the registry keys of the Intel compiler are defined.
