How to avoid words being replaced in line comments of PHP files by IntelliTips? (solved)
14
PostJan 07, 2015#1
I am having a problem with what I assume is an IntelliTips issue.
I am NOT able to type a single comment line or text string without the #@^(@ Editor replacing my words. I THOUGHT it was supposed to ignore things after a /*, //, or # and also things within ' ' or " "
Have I missed some toggle somewhere that will convince the editor to leave my stuff alone?
#I would like the following process to die properly
#i str_word_count(like , the)XML_OPTION_CASE_FOLDING dom_domdocument_createprocessinginstruction strtok(die(properly))
Really? I mean... REALLY?
PostJan 08, 2015#2
I suppose you are editing PHP files with file extension php or php5 and use installed syntax highlighting wordfile php.uew.
Which options do you have set in the configuration dialogs Auto-complete and Quick Tips at Advanced - Configuration - IDE - IntelliTips?
I have to ask this because with starting UEStudio with default settings, creating a Test.php (ASCII/ANSI) with first line containing <?php and third line containing ?> and typing in second line the comment line as posted by you nothing was replaced automatically by UEStudio although auto-completion was not disabled for comment blocks and strings (default settings).
14
PostJan 08, 2015#3
I think I uncovered the problems.
99% of it is a badly misconfigured (by me) Advanced - Configuration - IDE - IntelliTips - Auto-complete.
Like symbol list at 1 char, delete trailing chars, and complete with tabs AND enter.
The quick tips was also screwed up (again, me). I had it set to .5 sec.
All of that, combined with trying to test at the end of a large script, messed up my test example.
I will reassess, after setting better values, and if I am still having issues, I will re-post.
