When do files get parsed?
    Jul 12, 2006#1
    I'm really struggling with this feature. I can't seem to figure out why some files in my project are not being parsed. I have functions that just never show up?
    When does a file get parsed or reparsed?
    This really looks like a bug to me.
    Is it?
      Jul 15, 2006#2
      Look at Configuration - IDE - IntelliTips - Parser and the help about these settings.
        Jul 15, 2006#3
        I found the problem. The Java compiler I was using does not require a ; after an import statement
        import System;
        and the missing ; was completely shutting down UEStudios java parser, causing it to parse no further.
        It's really too bad that UEStudio doesn't support user configurable parsers. There are a lot of languages out there. I've requested this several times and just get a "I'll check with the programmers".
        It's too bad we don't get more meaningful response from them.
