Is it possible to create a project that consists of files on another server which is accessed via FTP?
Steve
Steve
Where is this located at? And were you trying to say you wished you knew why it DOESN'T work?DigitalSorceress wrote:That's how I use it too, but I really wish I understood why the "link to ftp/sftp folder" feature works... it seems like a really neat idea, but when I set up a project that way, it doesn't actually seem to do anything.
The Help documentation doesn't explain how to sync a project via FTP. Perhaps now that you've figured it out, you could share how to do it? I'd appreciate it.DigitalSorceress wrote:With Troy's help, I have managed to get it to link to my ftp server, but there is something screwy about the remote path. Even though I specify /home/username/target_dir/ as the remote path, the ftp download and sync functions start grabbing everything from the server / directory
I'm sure I'm just not doing SOMETHING right... the reason the link was forcing to a group type folder instead of an ftp link is that I was setting the folder name as "bin" when it needed to be in relative-to-project-dir-windows-path format (".\bin" as soon as I did that, the ftp folders were linking, but then I got the "ftp fetch the entire server starting at /" problem
