Is there any way to set some files in a project to open in a read only mode and have it remember those settings the next time you open the project?
It is not possible to specify that some of the project files should be always opened in read-only mode except you set the read-only file attribute for those files if this is possible.
There are only 2 config options which can help you Open files as Read-Only by default and Remember the Read-Only setting when reloading a file currently open at Configuration - File Handling - Load.
