UltraCompare closes when I am minimizing the application (solved)
PostSep 12, 2014#1
When I minimize UltraCompare, it immediately closes. Is this normal behavior? If not, how to I turn this off?
6,823625
PostSep 13, 2014#2
UC does not exit (close), it just minimizes to Windows system tray. Open Configuration from menu Options, select Application Layout, and uncheck on right side the setting Minimize to System Tray.
PostSep 15, 2014#3
Thank you that worked!
