I have two test files with identical format, but each file has the extract date and time. When I compare the files, every record is highlighted as unmatched. The character highlights do show that the only discrepant fields are extract date & time, but the file has thousands of records and I must scroll through the entire file to verify that there are no other discrepancies.
Is it possible to specify that a compare only compare specific columns? For example, in a 100-character record, only compare columns 1-50 & columns 69-100, skipping any comparison of columns 51-68, which contain the extract date and time.
