How to merge a single line of text and not the whole block?
    Jan 10, 2017#1
    I am a network engineer and all of the configurations for our networking devices are saved as text files. We use a standard template for most of our devices, but there are a lot of changes that need to be made.
    I am having difficulty just changing one line from the text_a to text_b. Instead it changes the whole block. I have tried using the line mode merge without much luck. I have also tried the advanced merge only to have the whole block changed.
    Does anyone know of a way to do a compare and only change one line at a time?
    Any help will be greatly appreciated.
    Thanks!
      Jan 11, 2017#2
      The merge mode Line Mode Merge (Ctrl+J) in menu Merge on using toolbar/menu mode must be enabled to merge a single line from first to second or from second to first.
      Additionally a single line must be selected in both panes by clicking on the line to merge in both panes. In the attached screenshot merge_single_line_first_to_second.png the line to merge has a yellow background color in both panes.
      It is also possible to merge a single line from second to first file or vice versa which is at a different position in file as the attached screenshot merge_single_line_second_to_first.png demonstrates where line 5 from second file is merged to line 7 in first file.
      The lower half on both screenshots shows the result after the single line merge.
      This screenshot shows how to merge line 6 from first file to line 6 in second file.
      This screenshot shows how to merge line 5 from second file to line 7 in first file.
      maui_scott
        Jan 13, 2017#3
        Thank you so much. I was missing clicking on the second pane. This is going to save me a lot of time!
