I fiddle around a lot wit WordPress themes, mostly with adding localization support. I also use TortoiseSVN for handling version control.
The "Create Patch"-feature allows me to select a bunch of file and create a file with differences of all the selected files, which is rater handy.
Does UltraCompare allow to do the same? I mean, create a difference file with the changes in a bunch of files at once? Or would i have to do it file by file? Is there at least a way, to append the changes to one difference file? Or do i have to create a difference file for each file pair?
