I've seen another topic covering this issue but it's time to resurrect it.
Why can't I select a single line from file and merge it to the other file, not before or after but replacing the line. Many times I'm comparing files that are extremely similar except for selected lines. Line Mode Merge would lead me to believe this is possible but it isn't. I'd have to merge whole block before or after then delete the unwanted lines from the merged-to file. Too much work. This is why I find myself using Beyond Compare for a lot if not most of my merges. It is much more intuitive that UC Pro.
