Strange symbol appears at end of line in UltraCompare
6
    Jan 28, 2010#1
    I am new to this.
    I am trying to compare two .php files, but because one of the two files shows a symbol at the end of every line in UC, every line is marked as being different.
    The symbol does not appear in the original file, only when it is loaded into UC. If I copy the symbol to my clipboard it shows as an empty space!
    Here is a screenshot of the symbol:
    Can anyone tell me what the red symbol is and how I get rid of it?
    I even tried copying lines from doc1 and overwriting doc 2 with them, but doc2 still shows the red symbol that is not seen on doc1
    Many thanks
    Tog
    There is a thin line between genius and insanity. I cross it often.
    pietzcker
    236
      Jan 28, 2010#2
      This is a paragraph marker. Are you possibly comparing two files in different line formats (ie, Windows vs. Unix)? In any way, in the configuation dialog, you can instruct UC to ignore these (Ignore Options - Text - Ignore line terminators). This option can be enabled also in submenu Options - File Ignore Options.
      For further reading, check out Jeff Atwood's blog post "The great newline schism".
      Wigwam
      6
        Jan 28, 2010#3
        Perfect, thank you so much for your lucid reply.
        Tog
