Searching and copying multi-line strings
18
    Jul 21, 2012#1
    Hi all:
    I hope someone can help me. I'm trying to extract repeative, multi-line keys from a *.REG file. Specifically, the e-mails. Now I've seen the post Convert REG_MULTI_SZ hex to text, and that will work just fine, once I get the lines out. Here is what I want to do
    ============= Begin "Cut down registry entries"
    "Account Name"= (hex strings like in the above post,some multi-line)
    "SMTP Use Auth"=(dword value)
    "Display Name"= (hex strings like in the above post,some multi-line)
    "Email"= hex:ff,00,ff,00,ff,00,ff,00,ff,00,ff,00,ff,00,ff,00,ff,00,\
    ff,00,ff,00,ff,00,ff,00,ff,00,ff,00,ff,00,ff,00,ff,00,ff,00,\
    "POP3 Server"= (hex strings like in the above post,some multi-line)
    "SMTP Server"= (hex strings like in the above post,some multi-line)
    "POP3 User"= (hex strings like in the above post,some multi-line)
    "POP3 Password"= (hex strings like in the above post,some multi-line)
    ============= End "Cut down registry entries"
    Of cource, the email entry above isn't a valid e-mail.
    What I'd like to do, is to extract the lines within the "Email=" area, in this case:
    Then put them into a new file, search and replace "Email"= hex: with nothing. After that, I will then run the script from "Convert REG_MULTI_SZ hex to text" manually.
    I tried to find an example of the finding of the strings, and copying them, but I couldn't (maybe I had a brain fart). But any help would be greatly appreciated.
    I have a large number of e-mails, and by extracting the entries from the registry makes it easier to see what, if any is missing.
    THANKS LOADS IN ADVANCE!
      Jul 21, 2012#2
      Well, this is an often required task and therefore there are a lots of macros and scripts showing how to do this. The user-submitted scripts page contains a reference to Filter lines script. There is also findMultiline.js on server of IDM not referenced on the downloads page. Well, this second script is just a very small script template and not a ready to use script. So I decided to quickly write this simple script exactly for what you need.
         // Define all parameters for the case-sensitive Perl regular expression
         // search used to find email address registry entries in active file.
         UltraEdit.perlReOn();
         // Set caret to top of active file and prepare user clipboard 9 for the data.
         UltraEdit.selectClipboard(9);
         UltraEdit.clearClipboard();
         // Run the search in a loop until no email address block could be found anymore.
         // Append to clipboard always all found characters selected in file except the
         // first 13 characters which are  "Email"= hex:  not interested in.
         while (UltraEdit.activeDocument.findReplace.find('^"Email"= hex:[0-9a-f][0-9a-f,\\\\\\r\\n]+')) {
         	UltraEdit.clipboardContent += UltraEdit.activeDocument.selection.substr(13);
            // For making it easier in new file to see where a block begins append an extra line termination.
         	UltraEdit.clipboardContent += "\r\n";
         // Paste the found blocks into a new file if a block was found at all.
         if (UltraEdit.clipboardContent != "") {
            UltraEdit.newFile();
         // Make the Windows clipboard active again.
         UltraEdit.selectClipboard(0);
