Auto IDs creation
Auto IDs creation
12
    Jul 04, 2016#1
    How to create auto IDs sequence of chapter-title, H1, H2, etc.?
    ID structure like <chapter-title id="ch1">, <h1 id="h1_1">, <h2 id="h2_1">
    Input
    <html>
    <head>
    <title>xxxxxxxxxxxxxx</title>
    </head>
    <body>
    <p class="ch-title">Was sind Existenzanalyse und Logotherapie?</p>
    <p class="h1">Die Wurzeln der Existenzanalyse und Logotherapie</p>
    <p class="h2">Die Wurzeln der Existenzanalyse und Logotherapie</p>
    </body>
    </html>
    Output file should be
    <html>
    <head>
    </head>
    <body>
    <p class="ch-title" id="ch1">Was sind Existenzanalyse und Logotherapie?</p>
    <p class="h1" id="h1_1">Die Wurzeln der Existenzanalyse und Logotherapie</p>
    <p class="h2" id="h2_1">Die Wurzeln der Existenzanalyse und Logotherapie</p>
    </body>
    </html>
    Apply for all "ch-title", "h1" and "h2".
    Kindly help me.
    6,684586
      Jul 07, 2016#2
      I do not really understand why using a standard paragraph with a class h1 and h2 instead of using HTML element H1 and H2, but here is the commented UltraEdit script which adds identifiers or updates existing identifiers if not having already the right number.
      if (UltraEdit.document.length > 0)  // Is any file opened?
         UltraEdit.columnModeOff();
         // A case-sensitive Perl regular expression search string is
         // used to find and update the chapter and heading identifiers.
         UltraEdit.perlReOn();
         var sNumber;
         var nChapter = 0;
         var nHeading1 = 0;
         var nHeading2 = 0;
         // Find from top to bottom of file in a loop class ch-title or h1 or h2
         // with or without an id attribute as next attribute after class attribute.
         while(UltraEdit.activeDocument.findReplace.find('(?<=class=")(?:ch-title|h1|h2)"(?: id="[^"]+)?'))
            // Get class ch or h1 or h2 from begin of found string.
            var sClass = UltraEdit.activeDocument.selection.substr(0,2);
            if (sClass == "ch")  // Is this a chapter?
               // Increase chapter number and convert it to a string.
               nChapter++;
               sNumber = nChapter.toString(10);
               // Is an id attribute already present?
               if (UltraEdit.activeDocument.selection.length > 16)
                  // Has the chapter not the right number, overwrite it.
                  if (UltraEdit.activeDocument.selection.substr(16) != sNumber)
                     UltraEdit.activeDocument.write('ch-title" id="ch' + sNumber);
                  else  // Chapter has already the right number, cancel selection.
               else     // Chapter has no identifier, add it.
                  UltraEdit.activeDocument.write('ch-title" id="ch' + sNumber + '"');
            else if (sClass == "h1")   // Is this a heading level 1?
               // Increase heading level 1 number and convert it to a string.
               nHeading1++;
               sNumber = nHeading1.toString(10);
               if (UltraEdit.activeDocument.selection.length > 11)
                  // Has the heading 1 not the right number, overwrite it.
                  if (UltraEdit.activeDocument.selection.substr(11) != sNumber)
                     UltraEdit.activeDocument.write('h1" id="h1_' + sNumber);
                  else  // Heading 1 has already the right number, cancel selection.
               else     // Heading 1 has no identifier, add it.
                  UltraEdit.activeDocument.write('h1" id="h1_' + sNumber + '"');
            else  // This a heading level 2.
               // Increase heading level 2 number and convert it to a string.
               nHeading2++;
               sNumber = nHeading2.toString(10);
                  // Has the heading 2 not the right number, overwrite it.
                     UltraEdit.activeDocument.write('h2" id="h2_' + sNumber);
                  else  // Heading 2 has already the right number, cancel selection.
               else     // Heading 2 has no identifier, add it.
                  UltraEdit.activeDocument.write('h2" id="h2_' + sNumber + '"');
