Hello, I try to repair a DXF file (drawing exchange format, CAD). The problem with this text file is, that because of the doubled names inside the file the import into the CAD program does not work. So I want to try the following:
If the text string "Building" is found the macro/script should rename the first string to "Building_01", the next to "Building_02" and so on. Is this possible with UE?
