Script to add a string at the end of line
8
PostDec 13, 2022#1
I need a script which will search for <CM> and if found on a line in the file it must append <CM> to the end of that line.
Example: The line contains:
die vyfde met <W •sardoniks><CM>die sesde met <W •karneool><CM>die sewende met <W •chrisoliet><CM>die agtste met <W •berilsteen><CM>die negende met <W •topaas><CM>die tiende met <W •chrisopraas><CM>die elfde met <W •hiasint><CM>en die twaalfde met <W •ametis>.
 It must end up like this:
die vyfde met <W •sardoniks><CM>die sesde met <W •karneool><CM>die sewende met <W •chrisoliet><CM>die agtste met <W •berilsteen><CM>die negende met <W •topaas><CM>die tiende met <W •chrisopraas><CM>die elfde met <W •hiasint><CM>en die twaalfde met <W •ametis>. <CM>
Is that possible?
I use UltraEdit version 18.10.0.1018.
6,826625
PostDec 13, 2022#2
A Perl regular expression replace all with (<CM>.+)$(?<!<CM>) as search expression and \1 <CM> as replace expression appends a space and <CM> at end of every line containing <CM> and not already ending with <CM>.
Recorded as UltraEdit macro:
PerlReOn
Find MatchCase RegExp "(<CM>.+)$(?<!<CM>)"
Replace All "\1 <CM>"
Written as UltraEdit script:
   // Define all parameters for a case-sensitive Perl regular expression
   // replace all executed from top of the file and execute the replace.
   UltraEdit.perlReOn();
   // In JavaScript strings a backslash is interpreted as escape character
   // and must be escaped itself with a backslash to define the regular
   // expression replace string with a literal interpreted backslash by
   // the JavaScript core engine.
   UltraEdit.activeDocument.findReplace.replace("(<CM>.+)$(?<!<CM>)", "\\1 <CM>");
8
PostDec 13, 2022#3
Thank you very much! It does exactly what I wanted.
