How to do multiple finds and replaces in active document with an UltraEdit script?
PostMay 15, 2023#1
Hello, I need a script to replace in the active document many strings and each string has a different replacement string.
For example:
Find: "wbrp01.i" replace: "{us/wb/wbrp01.i}"
Find: "{gprun.i " replace: "{us/bbi/gprun.i"
Find: "{mfdtitle.i}" replace: "{us/mf/mfdtitle.i}"
PostMay 16, 2023#2
Here is the simple script for the task. Please read the comments.
   // Define the two arrays with the strings to find and the appropriate replace strings.
   // Please note that the character \ in a find/replace string must be escaped with one
   // more \ as the backslash is the escape character in a JavaScript string.
   var asFind = ["wbrp01.i", "{gprun.i ", "{mfdtitle.i}"];
   var asReplace = ["{us/wb/wbrp01.i}", "{us/bbi/gprun.i", "{us/mf/mfdtitle.i}"];
   // Define all the parameters for the case-sensitive, non regular
   // expression replace all commands executed on entire active file.
   UltraEdit.ueReOn();
   // The number of strings to find and the number of replace
   // strings should be always identical. But make nevertheless
   // sure that there is never an array access out of bounce.
   var nReplaceCount = asFind.length;
   if (asReplace.length < nReplaceCount) nReplaceCount = asReplace.length;
   for (var nIndex = 0; nIndex < nReplaceCount; ++nIndex)
      UltraEdit.activeDocument.findReplace.replace(asFind[nIndex], asReplace[nIndex]);
      UltraEdit.activeDocument.top();  // This command should not be necessary, but
   }                                   // there are some UE/UES versions requiring it.
