Replace a string at the beginning of every line
    Sep 14, 2023#1
    Hi all,
    I want to replace all 0000 at the beginning of every line in the actual file with two letters AB with a script.
    00000012345678 . . .
    00000001234567 . . .
    00000000123456 . . .
    My code:
    UltraEdit.activeDocument.findReplace.replace("0000", "AB");
    Result:
    AB0012345678 . . .
    AB0001234567 . . .
    ABAB123456 . . .
    AB0012345678 . . ..
    My first try with a script is not really good.
    Line 3 should be:
    AB0000123456 . . .
    How to solve this problem?
    6,687587
      Sep 14, 2023#2
      There must be used a regular expression replace with the anchor % (UltraEdit) or ^ (Unix/Perl) for matching only 0000 at beginning of a line.
         // UltraEdit.columnModeOff() is for UltraEdit for Window while
         // UltraEdit.activeDocument.columnModeOff() is for UltraEdit for Linux/Mac.
         // Define all parameters for an UltraEdit regular expression replace
         // all in entire active file searching for the string 0000 at beginning
         // of a line and replace each found occurrence with the string AB.
         // The IF condition is for UltraEdit version 13.xx which does not have
         // the search in column feature. Just the line inside the IF condition
         // is needed on newer versions of UltraEdit.
         UltraEdit.ueReOn();     // UltraEdit regular expression engine
         UltraEdit.activeDocument.findReplace.replace("%0000", "AB");
      The last two lines above the last line with just } could be also:
         UltraEdit.unixReOn();   // Unix regular expression engine
         UltraEdit.activeDocument.findReplace.replace("^0000", "AB");
      or
         UltraEdit.perlReOn();   // Perl regular expression engine
        Sep 15, 2023#3
        Mofi, your code solution works for me.
        Thanks!
