runTool() does not set Focus to active Document
    Nov 03, 2007#1
    I have an external script that writes to the outputWindow. I copy that, process the output, write to activeDocument.
    After it runs, I seem to still be in the "Script List" (this is how I envoked it by dbl-clicking it).
    If I use the popup "Run", it works fine.
    If I envoke it in the Scripting Menu, it works fine.
    It just seems that dbl-clicking in there is my problem.
    How can I set focus back to the ActiveDocument?
    6,683583
      Nov 03, 2007#2
      What about using this simply code:
      // Remember the current active file before real start of the script.
      var CurrentFileIndex = getActiveDocumentIndex();
      // Your script code.
      // Make the file before script execution again the active file.
      if (CurrentFileIndex >= 0 && CurrentFileIndex < UltraEdit.document.length) UltraEdit.document[CurrentFileIndex].setActive();
      Here is the code for the function getActiveDocumentIndex.
      I hope this works because I have not tested it. If it does not set the focus to the edit window, write an email to IDM support.
        Nov 03, 2007#3
        Tried it out, but it still does not return focus back to the document.
        I tried "setActive()", but no luck.
        I think its just the way that "double-clicking" on the "Script List" keeps the focus and I do not see a way to "CTRL-TAB" back to the active one.
        For now, I'll just note that this is a problem (for double-click). but the other ways I mentioned all work ok.
        thanks.
