It would be really nice if you could write me a script. I am not good at programming and don't know java.
I have plenty of text files like the attached one (view here, UTF-8 ).
The point of interest for the script is all the lines containing a value of seconds (a number with one decimal digit). The lines can be found easily because they all begin with "\ELANBegin" or "\ELANEnd". Here is an excerpt:
for 268.1 the result would be 00:04:28:10
for 271.2 it would be 00:04:31:20
This result has to appear in round brackets after the decimal number. For the excerpt, the result would be
What the script shall do is to convert the highlighted number which represents seconds to a timestamp of the format hh:mm:ss:cs (i.e. hours:minutes:seconds:centiseconds)\ref NA071112-01_E.092
\cfn
\ELANBegin 268.1
\ELANEnd 271.2
\PAUSE 0.8
\ELANParticipant A
\cfn
\ELANBegin 268.1 (00:04:28:10)
\ELANEnd 271.2 (00:04:31:20)
\PAUSE 0.8
\ELANParticipant A
- na071112-01_e_in_progress.zip (12.59 KiB) 345
- encoded in UTF-8
