looping over lines in the selection
8
    May 19, 2008#1
    Is there a way to loop over each line in the current selection?
    e.g.
    for each line in selection
    // do something to this line if it matches criteria
    end for
    I see the selection property in the help but it is documented as read only.
    -Michael
    21
      May 20, 2008#2
      Don't know what exactly you want.
      May this will help you.
      UltraEdit.hexOff;
      UltraEdit.ueReOn();
      var CRLF = "\r\n"; /* LineFeed character */
      var myLines = UltraEdit.activeDocument.selection;
      lines = myLines.split( CRLF );
      for ( i in lines ) {
      //check any condition you want. here just true
       if ( true ) {
       lines[i] = "" + i + " " + lines[i];
       UltraEdit.activeDocument.write(lines[i]+CRLF);
      6,683583
        May 20, 2008#3
        And do you know that you can run a Replace All in the just selected area. With tagged regular expressions this method is normally the fastest and easiest method to reformat a selection.
        8
          May 20, 2008#4
          Thanks for the responses! It gives me some avenues to test.
          Basically, I just looking to write a script that will process a selection that contains lines of C++ declarations or definitions. One of the characters I need to manipulate is the semicolon at the end of a line. Replace All might compromise other semicolons (e.g. for loops) unless I use regular expressions... which I could do I suppose.
