Paste ASCII HEX with conversion to ASCII
    Jun 04, 2008#1
    I'd like to paste hex values into UltraEdit, so that they end up as ANSI text.
    F.e. the buffer contains:
    30:30:31:
    I'd like to paste into UltraEdit;
    001
    Using UltraEdit 14.00b
    TIA,
    Wessel
      Jun 04, 2008#2
      That's a conversion, not a simple paste. Therefore you need a macro or script which pastes first your ASCII presented hex data into a file and then runs replaces to replace them with the ASCII characters. For example with a macro it would be:
      NewFile
      Find "20:"
      Replace All " "
      Find "21:"
      Replace All "!"
      and so on for all other ASCII characters according to View - ASCII Table except 30-3A and 41-46 which must be at end of the macro.
      Find "7D:"
      Replace All "}"
      Find "7E:"
      Replace All "~"
      Find "30:"
      Replace All "#!0!#"
      Find "31:"
      Replace All "#!1!#"
      Find "32:"
      Replace All "#!2!#"
      Find "33:"
      Replace All "#!3!#"
      Find "34:"
      Replace All "#!4!#"
      Find "35:"
      Replace All "#!5!#"
      Find "36:"
      Replace All "#!6!#"
      Find "37:"
      Replace All "#!7!#"
      Find "38:"
      Replace All "#!8!#"
      Find "39:"
      Replace All "#!9!#"
      Find "41:"
      Replace All "#!A!#"
      Find "42:"
      Replace All "#!B!#"
      Find "43:"
      Replace All "#!C!#"
      Find "44:"
      Replace All "#!D!#"
      Find "45:"
      Replace All "#!E!#"
      Find "46:"
      Replace All "#!F!#"
      Find "3A:"
      Replace All ":"
      Find MatchCase RegExp "'#!^([0-9A-F]^)!#"
      Replace All "^1"
      The macro property Continue if search string not found must be checked for this macro. Add UnixReOn or PerlReOn at the end of the macro if you do not use UltraEdit style regular expressions by default - see search configuration. Macro command UnixReOff sets the regular expression option to UltraEdit style.
      262
        Jun 04, 2008#3
        And here is a script to do the same. Assign it a short cut key and it is pretty fast to paste-convert-hex-into-ascii. (Not testet for UTF8/Unicode files).
        var line = UltraEdit.activeDocument.currentLineNum; /* remember where to insert */
        var col  = UltraEdit.activeDocument.currentColumnNum; /* remember where to insert */
        if (typeof(UltraEdit.activeDocumentIdx) == "undefined") col++;
        UltraEdit.activeDocument.top(); /* go to top and paste hex eg. 30:30:31: */
        UltraEdit.activeDocument.paste(); /* paste clipboard contents */
        UltraEdit.activeDocument.selectToTop(); /* select it */
        var oStr = ""; /* outputvariable */
        if (UltraEdit.activeDocument.isSel()) { /* is anything selected ? */
          var isThisHex = UltraEdit.activeDocument.selection; /* get selected text */
          isThisHex = isThisHex.replace(/:/g,""); /* remove semicolons: Before: 30:30:31: After: 303031 */
          try {
           for (j=0;j<isThisHex.length;j=j+2) { /* iterate jumping 2 positions in each loop */
              var iChr = isThisHex.substr(j,2); /* read a single hex escaped character */
              if(iChr=="00") { /* hex 00 is suppressed as blank */
                 iChr="20"; /* hex 20 = blank */
              // Un-escape two character hex into single character
              oStr = oStr + String.fromCharCode(parseInt( iChr, 16 ));
          catch (conversionError) {
            /* do nothing if it can't be converted - Insert your own error handling */
        UltraEdit.activeDocument.deleteText(); /* delete pasted contents after it is retrieved */
        UltraEdit.activeDocument.gotoLine(line,col); /* go to original position in document */
        UltraEdit.activeDocument.write(oStr); /* write converted string */
          Jun 04, 2008#4
          First assumed script worked on selected text, but it works on the clipboard :) Great.
          Thanks a bunch,
          Wessel
