add time from regex fields in script
61
Advanced UserAdvanced User
61
    Aug 09, 2008#1
    I am having a problem wit this data
    kjg oejhgreg
    eig
    qegj rpqej gpq
    egj 'pierp'
    erg
       r
       gu eg
       u g
       p  u g
       p  u g
       p  u g
       p  ue gp
       eg pue  gpue qg
    Elapsed: 01:10:00.66
    'lgk sdl;jgad;ojg ad
    gag
    fagk
    fa
    gka
    gk
    Elapsed: 00:33:44.00
    agad
    gfa
    g
    ga
    g
    ag
    ag
    g
    Elapsed: 00:00:55.23
    ag
    ag
    adgf
    ag
    ad
    gfa
    dh
    dhs
    fhf
    jhdsjy
    dgj
    gj
    Elapsed: 00:08:32.77
    h
    fgd
    gfswd
    hgwr
    hwr
    ht
    wrh
    wrh
    wrh
    w
    Elapsed: 00:50:00.12
    ashaswhtwsrhwrthrwhwrthwrthwrth
    sfdth
    wrh
    wr
    hw45
    h45w
    h
    w456h
    2456h
    52w6
    h526
    h562
    h5
    h5
    64h5
    h5
    h56
    h
    Elapsed: 00:16:00.01
    wiy rtpio3qytgpiu31qy gtipuq3yh tg3
    Elapsed: 00:19:00.40
    e
    rtweb5
    tw
    5tbqw43
    b6tq3
    6q6
    q6
    23
    324
    6
    Elapsed: 00:31:00.56
    qt
    34b63
    6
    6
    q26
    w234
    562
    4652
    4b6
    Elapsed: 03:00:00.12
    rtqw
    4etyb23q4
    6234
    62q43
    62q34
    562q
    462q43
    62q
    66
    Elapsed: 00:00:44.11
    twe
    y245b
    67y24
    7y642w
    y7w4
    y75n w4
    57y6nw 4
    5b
    56 46
    7w7
    45
    7nw475
    Elapsed: 00:00:22.99
    h
    e5thn
    5 h
    2 54y6
    2y
    45 y
    y4
    y
    4y5
    y45
    45y
    y4
    2y
    654y
    Elapsed: 00:00:10.03
    ka
    ;lkgv
    kbf
    fbgk
    qewbg
    wqre
    bgt
    qwertbgk
    q4rekgt
    q4tkg
    4q1gk
    4qpg
    1435jgt
    1j435gh
    Elapsed: 00:00:04.00
    iah epfghqepuoir gpueiqgypuiqeygipuqeyguiqg:
    Elapsed: 00:00:00.00
    here is the code to add the times up and print in the output window, but it is not working all help is appreciated
    // Define working environment for this file.
    UltraEdit.perlReOn();
    var t1,t2,t3,ttime
    // Helper function as UE does not recognize start and ending slashes in regexp
    RegExp.prototype.toUEregexp = function() { return this.toString().replace(/^\/|\/$/g, ""); }; /* remove starting and ending slashes */
    // Where to find the parmfile:
    var parmfile = "c:\\temp\\sample_timing.txt";
    // Now go get parm file and parse it into an array of parameters
    var parms = getParms(parmfile);
     UltraEdit.outputWindow.write( parms.length );
    if(parms.length != 0) {
    for(var i=0;i<parms.length;i++) {
          ttime= ttime + parms[i];
     t1 = parseInt( ttime/3600 );
    /* Parse parameter document to get parameters */
    function getParms(parmfilePath) {
      var parsedParms = new Array();
      // Open parm file if not open already
      var parmdocIx = getDocumentIndex(parmfilePath);
      var parmdocOpen = true;
      if(parmdocIx==-1) { /* not open */
        UltraEdit.open(parmfilePath);
        parmdocOpen = false;
      if(parmdocIx==-1) { /* just in case, no parm file found */
        return parsedParms;
      // Define all the replace options to correct execute the follwing 2 replace all commands.
      UltraEdit.document[parmdocIx].findReplace.mode=0;
      UltraEdit.document[parmdocIx].findReplace.searchDown=true;
      UltraEdit.document[parmdocIx].findReplace.searchInColumn=false;
      UltraEdit.document[parmdocIx].findReplace.matchCase=false;
      UltraEdit.document[parmdocIx].findReplace.matchWord=false;
      UltraEdit.document[parmdocIx].findReplace.preserveCase=false;
      UltraEdit.document[parmdocIx].findReplace.regExp=true;
      var reParms = /Elapsed: ([\d]{2}:){2}[\d]{2}\.[\d]{2}/; /* perl regular expression */
      UltraEdit.document[parmdocIx].top();
      // Loop and find all parameters
      while (UltraEdit.document[parmdocIx].findReplace.find(reParms.toUEregexp())) {
        // retrieve found parameter definition
        var foundParmDefs = UltraEdit.document[parmdocIx].selection;
    // UltraEdit.outputWindow.write( foundParmDefs )
     t1 = foundParmDefs.substr(9,2);
     t2 = t1 * 3600;
     t1 = foundParmDefs.substr(12,2);
     t2 = t2 + ( t1 * 60 );
     t1 = foundParmDefs.substr(15,5);
     t2 = t2 + t1;
     // add up total in seconds format is sssssss.hh
     // after adding I only care about sssssss
    // t3 = t3 + t2;
        // collect pairs of parameter definitions into array:
       parsedParms.push( [parseInt(t2)] );
      if(parmdocOpen==false) { /* not open, then close again on exit */
        UltraEdit.closeFile(UltraEdit.document[parmdocIx].path,2);
      return parsedParms;
    /* getDocumentIndex(filepath) */
    /* If called without parameter = Find the tab index of the active document */
    /* If called with parameter "filepath" = Find the tab index of that document. -1 = document not found */
    function getDocumentIndex(filepath) {
        if(filepath) {
          if (UltraEdit.document[i].path.toLowerCase().indexOf(filepath.toLowerCase())!=-1) {
            tabindex = i;
            break;
        else {
            tabindex = i;
            break;
      return tabindex;
      Aug 09, 2008#2
      Any help in making this script better would be appreciated.
      var t1,t2,t3,t4,ttime
      var parms = [] ;
      getParms(parmfile);
       UltraEdit.outputWindow.write( ' ' + parms.length );
       ttime = 0;
             ttime += parms[i];
             t1 = parseInt((parms[i]/100)/3600);
             t2 = parseInt(( (parms[i]/100) -( t1 * 3600) )/60);
             t3 = parseInt((parms[i]/100) - ( t1 * 3600) - ( t2 * 60));
         UltraEdit.outputWindow.write( "Step" + ( i + 1 ) + " ran for " + parseInt(t1) + " hrs " + parseInt(t2) + " min " + parseInt(t3) + " sec"  );
             t1 = parseInt((ttime/100)/3600);
             t2 = parseInt(( (ttime/100) -( t1 * 3600) )/60);
             t3 = parseInt((ttime/100) - ( t1 * 3600) - ( t2 * 60));
         UltraEdit.outputWindow.write( "Total run time " + parseInt(t1) + " hrs " + parseInt(t2) + " min " + parseInt(t3) + " sec"  );
          return parsedParms;
       t2 = foundParmDefs.substr(12,2);
       t3 = foundParmDefs.substr(15,5);
       t4 = parseInt( t1 * 360000 ) + parseInt( t2 * 6000 ) + parseInt(t3 * 100);
       UltraEdit.outputWindow.write( t1 + " " + t2 + " " + t3 + " " + t4);
         parms.push(  t4 );
          if(filepath) {
              tabindex = i;
              break;
          else {
              tabindex = i;
              break;
        return tabindex;
      262
        Aug 10, 2008#3
        sklad2 wrote:Any help in making this script better would be appreciated.
        Okay, too much time on my hand (or maybe just an excuse not to do the dishes ;-) )
        I have introduced the JavaScript Date() object into your script:
        https://www.w3schools.com:443/jsref/jsref_obj_date.asp
        otherwise I have renamed some variables so they relate to what they contain. I also added one of my JavaScript favorites: The destructing assignment in combination with Regexp exec method:
        var [ ,hrs,mins,secs,milli ] = reElapseTime.exec(foundElapseTime);
        I hope it was Ok to go beyond fixing whatever errors were in the script ! Have fun!
        // Helper function for Date object to return total hours (can exceed 24 hours)
        Date.prototype.getTotalHours = function() { return parseInt(this.getTime()/3600000,10); }
        // Where to find the timing file:
        var timingfile = "c:\\temp\\sample_timing.txt";
        // Now go get timing file and parse it into an array of elapse times
        var elapseTimes = getElapsetimes(timingfile);
        var ttime = 0;
        UltraEdit.outputWindow.write( ' ' + elapseTimes.length );
        if(elapseTimes.length !== 0) {
           for(var i=0;i<elapseTimes.length;i++) {
              ttime += elapseTimes[i].getTime(); /* get millis since 1/1-1970 and add to total */
              UltraEdit.outputWindow.write( "Step" + ( i + 1 ) + " ran for " + elapseTimes[i].getUTCHours() + " hrs " + elapseTimes[i].getUTCMinutes() + " min " + elapseTimes[i].getUTCSeconds() + " sec"  );
        var totalElapse = new Date();
        totalElapse.setTime(ttime); /* set time for totalElapse using summed up milli secs */
        UltraEdit.outputWindow.write( "Total run time " + totalElapse.getTotalHours() + " hrs " + totalElapse.getUTCMinutes() + " min " + totalElapse.getUTCSeconds() + " sec"  );
        function getElapsetimes(timingFilepath) {
           var parsedElapseTimes = new Array();
           var timingDocix = getDocumentIndex(timingFilepath);
           var timingDocopen = true;
           if(timingDocix==-1) { /* not open */
              UltraEdit.open(timingFilepath);
              timingDocopen = false;
           if(timingDocix==-1) { /* just in case, no parm file found */
              return parsedElapseTimes; /* empty array */
           UltraEdit.document[timingDocix].findReplace.mode=0;
           UltraEdit.document[timingDocix].findReplace.searchDown=true;
           UltraEdit.document[timingDocix].findReplace.searchInColumn=false;
           UltraEdit.document[timingDocix].findReplace.matchCase=false;
           UltraEdit.document[timingDocix].findReplace.matchWord=false;
           UltraEdit.document[timingDocix].findReplace.preserveCase=false;
           UltraEdit.document[timingDocix].findReplace.regExp=true;
           var reElapseTime = /Elapsed: ([\d]{2}):([\d]{2}):([\d]{2})\.([\d]{2})/; /* perl regular expression */
           UltraEdit.document[timingDocix].top();
           while (UltraEdit.document[timingDocix].findReplace.find(reElapseTime.toUEregexp())) {
              var foundElapseTime = UltraEdit.document[timingDocix].selection;
              // assign using destructuring assignment and "reparsing" with regexp exec method:
              var newElapse = new Date();
              newElapse.setTime(0);
              newElapse.setUTCHours(hrs);
              newElapse.setUTCMinutes(mins);
              newElapse.setUTCSeconds(secs);
              newElapse.setUTCMilliseconds(milli * 10); /* 3 digits in javascript Date object */
              UltraEdit.outputWindow.write( UltraEdit.document[timingDocix].selection +">>" + newElapse.toUTCString() );
              parsedElapseTimes.push( newElapse );
              if(filepath) {
                    tabindex = i;
                    break;
              else {
                    tabindex = i;
                    break;
           return tabindex;
        (Hint: If you are having problems with your script: Start by running JavaScript Lint on it...)
        61
        61
          Aug 10, 2008#4
          Thank you for helping again. I like this alot.
