Delete empty lines
Delete empty lines
    Jun 29, 2009#1
    Hello
    I try to delete all empty lines in an active document. Unfortunately following script doesn't work. Can anybody tell me where is the problem?
    UltraEdit.activeDocument.findReplace.replace("%^p","");
    It seems that the RegExpfind string won't found. If I change the RegExp to something else, everything works fine.
    Thank's a lot for every support!
    Regards, Joerg
    6,683583
      Jun 29, 2009#2
      Whenever a script uses a find or replace (regexp or normal), the (regexp) engine must be set first. Also always specify once all find/replace options. Never let your script depend on internal defaults. An internal default could change in future.
      UltraEdit.ueReOn();
      // Not important here, but case-sensitive searches are in general faster.
      UltraEdit.activeDocument.findReplace.replace("%[ ^t]++^p","");
      The modification in the search string results in deletion of lines containing only spaces/tabs too.
        Jun 29, 2009#3
        Hi Mofi
        thank's a lot for your fast help.
        That's exactly what I need.
        GREAT!
        Have a nice afternoon.
