How to create a new binary file from a string with hex values in ASCII?
    Jul 23, 2009#1
    Hi there,
    I have a problem trying to create a binary file using UltraEdit.
    For example, I have an ASCII string as follows:
    "0123456789abcdef"
    and I need to create a binary file that contain the string above.
    So the file will contain
    0x01 0x23 0x45 0x67 0x89 0xab 0xcd 0xef (in total the size of the file will be 8 bytes).
    In fact, I have a string of 1000 hexadecimal bytes and I don't think I want to type it manually using hex edit function.
    Any help would be appreciated.
    cheers
    Rudy
      Jul 23, 2009#2
      Quite simple using a script. Tested on your example and some others with UE v15.10.0.1019. The script expects the string in the current clipboard.
      // This little script writes an ASCII string like
      // FFFE540068006900730020006900730020006A00750073007400200061006E0020006500780061006D0070006C0065000D000A006F0066002000610020006D0075006C00740069002D006C0069006E006500200073007400720069006E0067000D000A0065006E0063006F00640065006400200069006E0020005500540046002D003100360020004C0045002E00
      // into a new file in hex edit mode. The string must be in the active clipboard.
      var sHexValues = UltraEdit.clipboardContent;
      var nValueCount = sHexValues.length;
      var sErrorText = "";
      if (nValueCount > 0) {           // Is clipboard not empty?
         if (!(nValueCount % 2)) {     // Is the number of characters even?
            // Does the string only contain valid hexadecimal characters?
            if (sHexValues.search(/[^0-9a-f]/i) < 0) {
               UltraEdit.newFile();
               UltraEdit.activeDocument.write("!");
               UltraEdit.activeDocument.hexOn();
               UltraEdit.activeDocument.hexDelete(1);
               UltraEdit.activeDocument.write(sHexValues);
               // The next 2 lines are required to see the binary data correct in hex edit mode.
               UltraEdit.saveAs("");
            } else sErrorText = "Clipboard contains non hexadecimal characters!";
         } else sErrorText = "Clipboard contains odd number of characters!";
      } else sErrorText = "Clipboard is empty!";
      if (sErrorText != "") {
         if (UltraEdit.outputWindow.visible == false) UltraEdit.outputWindow.showWindow(true);
         UltraEdit.outputWindow.write("Error: "+sErrorText);
