GOAL: To locate within a specified folder/share and within files that have a file name pattern, 2 lines of text that in which line 1 begins with 2 '/' characters (i.e. //TextToFind ) and is followed by 1 word and then 1 or more spaces and then on line 2 begins with 0 to many spaces followed by a key word and then replace the text on line 2 with itself plus the file name & path, the current date and a fixed piece of text.
In order to keep this as non-verbose as possible I decided the best and easiest way to articulate what I am trying to do is to give a specific example.
The directory I will be searching in and the name of a file I would want to edit within that directory are listed below:
FILE NAME: rs_This_Is_My_Report.txt
FILE LOCATION/PATH: \\MyFileShare\MyFiles\
Within this file there is the following 3 lines of text and these 3 lines are not the first 3 lines in the file.
NOTE: In the CODE sections below the TABLE_A & TABLE_B text are supposed to be aligned but for some reason they don't appear that way in the below CODE boxes and I did use spaces only and no tabs so don't let that throw you. The number of spaces on in line 3 below are 9.
I want to edit this second line of text so that everything after the word "SELECT" is pushed down to a new line (not just added to what is already in the following line in this file) and also add to line 2 a string of text that consists of both fixed text and some dynamic text like the name of the file being edited.
This is what the edited lines should look like after the 'Replace In Files' is complete:
In this example the string of text is a comment as delimited by the "/*" and "*/ " which are used in the T-SQL language to indicate commented text. Within this string of text I have added several Name/Value pairs in which some of the values are fixed like the date and some are dynamic like the file name. The file path can be fixed because I will be searching in only 1 directory, but I am searching thru hundreds of files and so the FileName will need to be dynamic.
My end goal is to add to several hundred txt files this string of text consisting of Name/Value pairs and not do it manually 1 file at a time. I'm OK with using the START button in the REPALCE IN FILES function (as opposed to REPLACE ALL) and verify each replace in each file; I just don't want to have to manually add the text with as many files as I need to edit.
I also need to point out that a file may have more then one instance of a line of text that matches this pattern and that’s OK. If there is a file with more than one matching line then replacing all instances of the line in a file is what I want.
I hope I have explained this properly and that someone (probably Mofi) will have some suggestions on how to do this if it is in fact possible. I have posted this in the UE section because the UEStudio has no REPLACE/REGEX forum and because if this is doable it could be of benefit to others who use UE and not just users of UEStudio.
Please don't hesitate to ask any questions and I look forward to your comments.
//SELECT
SELECT TABLE_A.Column1 AS 'MyColumn_01',
TABLE_B.ColumnX AS 'MyColumnX',This is what the edited lines should look like after the 'Replace In Files' is complete:
//SELECT
SELECT /*XXXXX;FilePath=\\MyFileShare\MyFiles\;FileName=rs_This_Is_My_Report.txt;Date=2010/10/01;Area=Main;*/
TABLE_B.ColumnX AS 'MyColumnX',My end goal is to add to several hundred txt files this string of text consisting of Name/Value pairs and not do it manually 1 file at a time. I'm OK with using the START button in the REPALCE IN FILES function (as opposed to REPLACE ALL) and verify each replace in each file; I just don't want to have to manually add the text with as many files as I need to edit.
