I have to type characters twice in the editor (solved)
PostJun 05, 2014#1
Hello all,
I have the oddest issue, I am required to type every character twice to get the text to show up properly.
So, if I type "This" I get "hs"
I am running UEX Version 4.0.2.5 under Ubuntu server 14.04 LTS - 64-bit
Please don't hit me for installing gnome on a server :)
This was not an issue when I first installed UEX. So I am under the impression that I have fumbled some key combo to make this happen.
I have been using UE under Windows for over 10 years and I have never seen this issue pop up.
I attempted a few things to correct the issue but had no luck.
Has anyone seen this issue before?
Thank you in advance.
6,823625
PostJun 06, 2014#2
Do you have tried resetting the key mapping of UEX by opening Preferences - Key Mapping and clicking on button Defaults?
Further I suggest to check the hotkeys of scripts and macros.
Last check which keyboard is configured for input.
PostJun 13, 2014#3
Hi Mofi
Ya know. Those simple solutions are the embarrassing ones :)
Somehow I changed the keyboard config, or at least resetting it fixed the issue.
I should have thought of that.
Thank you.
PostAug 27, 2014#4
Hi folks,
I experience the same problem on Lubuntu 14.04 (Trusty Tahr) x86 with LXDE and UEX 4.2.0.11. I have to type characters twice to get them written down. Resetting the Key Mapping to Defaults did not work for me!
When I run uex as root (gksu uex), the problem disappears, but this is no good solution for me. I tried deleting the .idm folder in my home directory, but also did not work. I also disabled my lxde shortcuts, but that also did not help.
I'm looking forward to any suggestions.
Kind regards,
Mike
6,823625
PostAug 27, 2014#5
DavidBurton fixed the issue with resetting keyboard configuration of Linux and not by setting hotkey configuration in UltraEdit to default.
As there is no problem with using another user account (root), there is most likely also a problem with keyboard configuration in Lubuntu 14.04 for your user account.
PostAug 27, 2014#6
reconfiguring the Keyboard "in Linux" (dpkg-reconfigure keyboard-configuration) also did not work for me! In other editors like leafpad / jEdit / Geany everything works fine.
NOT SOLVED for me.
6,823625
PostAug 28, 2014#7
I'm 100% sure that the problem is not UEX, it is a keyboard configuration issue.
It is also on Windows possible to use for application A keyboard layout X and for application layout B keyboard layout Y. And this change in input language can be done with a system wide hotkey. Pressing left Shift+Alt and leaving them without any further key pressed results in switching the input language for active application. I have read here that it is possible to switch also on Ubuntu the input language with left Shift+Alt if configured accordingly. My suggestion for solving switching input language by mistake is to simply remove all input languages (keyboard layouts) which should not be used to have finally only one suitable to real keyboard making the shortcut to switch input language inactive automatically.
Look for solutions on other websites. For example, see:
As I don't use for myself whether Ubuntu 14.04 nor Lubuntu 14.04 nor Linux at all, I cannot give a step by step instruction on how to fix wrong keyboard configuration for UEX.
PostAug 29, 2014#8
Hell YEAH,
killing the ibus-daemon
or uninstalling it (apt-get purge ibus)
finally did it!
Thanks for your hint, Mofi!!! :lol: :D :)
