Wordfile storage on Linux (CentOs)
6
PostSep 14, 2015#1
Hi!
I've just downloaded and installed UltraEdit for Linux 15.1 on my new CentOs installation. I need to add a wordfile I've used in UltraEdit on Windows (language: Rexx). I moved (as root) the rexx.uew file from Windows to /usr/local/share/uex/wordfiles.
Now if I open UEX as root, then it lists Rexx among the other ones. So it reads my rexx.uew file. OK!
BUT if I open UltraEdit from any other normal user (not as root), the rexx.uew is not read and I don't see the Rexx visualization among the other ones.
I checked the permissions of rexx.uew and they are the same as others *.uew files in the same directory.
Any idea or suggestion?
Thanks in advance!
6,823625
PostSep 14, 2015#2
I'm not using UEX, just UE for Windows.
But in UE for Windows the path to the wordfiles directory is customizable at Advanced - Configuration - Editor Display - Syntax Highlighting.
So open Preferences dialog in UEX (I think, the menu item is in menu Edit) and navigate in tree to Editor Display - Syntax Highlighting. Is there a directory path displayed for the wordfiles directory?
6
PostSep 15, 2015#3
Hi!
In Linux I've discovered there are much less configurations and settings from menu... :-(
Anyway my problem has been solved by IDM official support:
The *.uew files should be copied into user account related directory: /home/username/.idm/uex/wordfiles respectively ~/.idm/uex/wordfiles
Copying the *.uew file just into common directory /usr/local/share/uex/wordfiles is not enough.
The official documentation doesn't tell anything about this, I hope IDM will declare so in coming Linux releases.
Thanks anyway for the fast reply.
6,823625
PostSep 19, 2015#4
Hi Ssardo!
Thanks for not just asking, but also posting the solution. That is definitely helpful for other UEX users.
Now I know from your post:
%APPDATA%\IDMComp\UltraEdit is the user account related application data directory of UltraEdit on Windows (on using default INI file location).
~/.idm/uex is the user account related application data directory of UltraEdit on Linux.
%APPDATA%\IDMComp\UltraEdit\wordfiles is the user account related wordfiles directory of UltraEdit on Windows (on using default INI file location and having not customized a different directory as wordfiles directory).
~/.idm/uex/wordfiles is the user account related wordfiles directory of UltraEdit on Linux.
%ProgramFiles(x86)%\IDM Computer Solutions\UltraEdit\wordfiles is the common wordfiles directory of 32-bit UltraEdit on Windows from which Uedit32 copies the *.uew files into the user account related wordfiles directory on start if there is no %APPDATA%\IDMComp\UltraEdit\wordfiles directory with 0 or more *.uew files (on having kept default program files directory for 32-bit UltraEdit on Windows x64 during installation).
/usr/local/share/uex/wordfiles is the common wordfiles directory of UltraEdit on Linux for the root user, and from which UEX copies the *.uew files into the user account related wordfiles directory on start if there is no ~/.idm/uex/wordfiles directory with 0 or more *.uew files for all users except the root user.
79
Advanced UserAdvanced User
79
PostSep 19, 2015#5
It would be nice if UEx would first look in the home directory: "/home/username/.idm/uex/wordfiles" then if a wordfile isn't found there look in the shared "/usr/local/share/uex/wordfiles" directory.
