UEX 2023 on Ubuntu 20.04?
PostOct 18, 2024#1
You only list Ubuntu 22.04 and 24.04.  Does either of these work on 20.04?  If not could you compile one up?  I use 20.04 for various compatability reasons and have a Ubuntu Pro account so it should be good for some years yet. :)
6,823625
PostOct 18, 2024#2
This is a user to user forum. You must address your questions regarding to UltraEdit for Linux v2023.0.0.21 with an email to support of UltraEdit, Inc. or using the technical support form.
There can be tried the installation on Ubuntu 20.04 with the GZip compressed TAR package for Ubuntu 22.04. UltraEdit for Linux v2023.0.0.21 cannot be used on Ubuntu 20.04 if uex does not run after extraction and there are no Ubuntu 20.04 backports of the libraries in the version required by UEX v2023.0. There is the old power tip: How to use the UltraEdit for Linux tar package? It may help on the installation without a suitable DEB package.
PostNov 04, 2024#3
fyi, I tried the tar package, but I get:
uex: /lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.30' not found (required by uex)
uex: /lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.29' not found (required by uex)
uex: /lib/x86_64-linux-gnu/libstdc++.so.6: version `CXXABI_1.3.13' not found (required by uex)
uex: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.32' not found (required by uex)
uex: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by uex)
uex: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by uex)
My system:
> uname -a
Linux xxxxxxxx 6.1.65-060165-generic #202312031100-Ubuntu SMP PREEMPT_DYNAMIC Sun Dec  3 12:00:13 UTC x86_64 x86_64 x86_64 GNU/Linux
> lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.6 LTS
Release: 20.04
Codename: focal
