I am on a Mac, using UE v2023.0.0.22
I find that very often, when I click on a file tab it seems to instantly split to a new pane. I have to constantly drag the tab back to my main tabs.
I found that what is happening is that if I move the mouse *at all* when I click on the tab, it does this. My hands are not steady, and this happens a lot. Often I'm just choosing a file by clicking on the tab, or maybe trying to manually re-order it.
Is there a way to adjust the sensitivity/timing of this so that I actually have to pull the tab off in order for it to pull out? If not, is there a way to completely disable this feature?
Regards
Ed
Regards
Ed
