Good day all!
Long time user that put Windows in the rear-view a few years back, and it occurred to me the other day that the only thing I really miss is UltraEdit
After a short wrestle I have managed to get both UltraEdit and UltraCompare working inside a flatpak.
However, I can't see anyway to link UltraEdit from UltraCompare. (I can link UltraCompare from UltraEdit … see screen.)
Can anyone please tell me if there's a config option or setting that I can use to ensure that UltraCompare can find UltraEdit? (Similar to the corresponding one in UltraEdit?)
Thanks for any help
PS: Flatpak: I'm testing with `org.geany.Geany` as this has the gtk dependencies already met: annoyingly I needed to get a few older libs from Debian repositories to satisfy all of UltraEdit's dependencies. Within flatpaks the /usr and /bin paths are read-only and can't be modified after they have been built, so I can't put the binaries in the "usual spot".
Thanks for any help
- Linux UltraCompare Professional path configuration in UltraEdit for Linux
