Auto Complete on mac?
7
    Mar 05, 2012#1
    Hi all--
    I can't figure out how to get auto complete to... complete!! I have it turned on, and when I type, I do see the little window pop up with suggestions. However, I have to manually scroll over it with my mouse, click inside the box, THEN I can use the arrows/mouse to highlight the entry I want, and hit enter. This really does nothing towards saving time, rather, it just makes things slower. This would be an extremely helpful feature, if only I could figure out a way to use it.
    When the window pops up.. I've tried hitting 'tab', 'enter' 'return' 'right arrow' 'left arrow', everything, to make selections active inside the auto complete.
    What am I doing wrong? Help! :)
      Mar 06, 2012#2
      Well.... I typed 2 characters of a word... AutoComplete Box popped up... I hit the DOWN arrow a few times... then return... worked just fine
        Mar 07, 2012#3
        I too have the same issues. When the little box appears, I can't do anything except click with the mouse inside the box, *then* use the arrow keys to select.
        If I press the down arrow when the box appears, it causes the box to disappear and the cursor moves down a line in the code. It seems as if the box doesn't get selected by default.
        This issue is keeping me away from buying an upgrade at this time.
        7
          Mar 14, 2012#4
          Glad to know I'm not the only one. That's a perfect description of what's also happening to me.
          If there are any suggestions on how to fix this, it's greatly appreciated.
          6,663562
            Mar 14, 2012#5
            I'm not using UltraEdit for Mac and therefore just watched this topic. What I miss here in the discussion is the version number of UEM and the version of the operating system. Perhaps this issue exists only for a specific version of UEM or under a specific version of the operating system.
            7
              Mar 14, 2012#6
              I'm running UE 3.0.0.11 on a MacBook Pro running 10.7.3
              IDM wrote:Concerning auto-complete, this is a known issue that our developers are working to resolve. I have added your name to our internal tracking system so we can contact you when a fixed build is ready for you to test.
                Mar 20, 2012#7
                I'm running the same version of UEM (3.0.0.11) on a new iMac running Mac OS X 10.7.3.
                15
                  Jul 30, 2012#8
                  Apparently this is fixed in UEM 3.1.0.1 on OSX 10.6.8. At least it works for me. :)
                    Nov 12, 2012#9
                    I still cannot get this to work, on Mac 10.8.2 and UE version 3.3.02. At least it is not working with keystrokes, if I select the text with my mouse, it will highlight and then I can hit return, but not with keys. Anyone know the proper way to select the recommended word and apply it?
                    15
                      Nov 13, 2012#10
                      Autocomplete no longer works for me with the new release (3.3.0.2 on 10.6.8 ). When I type two letters (my autocomplete minimum number of characters) the box shows up with one or more choices, but the first choice has a grey background instead of bold blue (for me). if I hit the down arrow, the box goes away. If I click on a word in the box, it becomes highlighted. Return will then pick that one and go on.
                      Oddly enough, once I click on one of the words in the box, I can change my choice with the up/down arrow, but I can no longer click on an alternate word.
                      Hopefully this will be fixed in the next minor release. :)
                      Travis
                        Dec 04, 2012#11
                        This appears to be fixed again in 3.3.0.4.
                        Can anyone verify this?
                        Travis
                          Dec 16, 2012#12
                          It's still the same problem with auto-complete in Version 3.3.0.4 (Mac OS X 10.8.2) as Travis mentioned.
                          Unfortunately ! :(
                          Hans-Joerg
                          341
                            Dec 17, 2012#13
                            I just tried this UE 3.3.04 .... OSX 10.7.5
                            when I type two characters.. the dropdown box appears.. first word is BLUE BOLD... I can use the arrows to move up and down within the box, and pressing RETURN completes the currently selected word.
                            BUT.... clicking with the mouse to select a word has NO effect. I must use Arrow keys, and RETURN
