OS X - Command + Tab Behavior (solved)
    Aug 06, 2012#1
    The workflow I use on my macbook pro has me switching between applications using the 'command + tab' application switcher.
    This is causing intermittent issues with UltraEdit. If UltraEdit has focus when I press 'command + tab' two windows pop-up. The window in focus says 'Search String ',' Not found!' Behind that pop-up is another window that says 'Press CANCEL to abort the current operation...' When I click the 'Ok' button on the 'Search String ',' Not found!' window both windows go away.
    I checked the 'Key Mapping' in the UltraEdit 'Preferences' but nothing is currently using the 'Command + Tab' key combination. For the life of me I can't figure out what is causing this behavior and therefore I'm at a loss on how to stop it.
    Can anyone provide any information on why this is happening?
    You can see a screencast of this behavior here: http://www.screencast.com/t/yhMateNDY
    341
      Aug 08, 2012#2
      command+tab works for me in OSX as it is meant to ... WITH UE running....
      and I have NOT added or deleted any keyboard commands....
        Aug 14, 2012#3
        !! SOLVED !!
        I finally figured out what was causing this behavior.
        If I do a quick record of a macro and don't 'unload all' after I'm done with the macro then using cmd + tab is causing the macro to execute again.
        I looked on the key mapping configuration and there is no mapping of any kind regarding macros and the cmd + tab key combination so I have think this is either a default shortcut or an undocumented feature (bug).
        Try a test yourself. 'Quick record' a macro of some text input in UE (I recorded myself typing "Hello World!') Now 'stop recording'. Next try the cmd + tab key combination. Every time you shift focus away from UE the macro will execute. After a few tests choose 'unload all' from the macro submenu. Try the cmd + tab again. Notice that your macro is no longer executing.
        341
          Aug 14, 2012#4
          you might want to send that directly to IDM as a bug report....
          There are certain keys that need to stay reserved for OSX
            Aug 15, 2012#5
            Thanks, Dave.
            I submitted a bug report to IDM.
