Long string problem on UltraEdit for Mac 18.00.0.17 (fixed with 18.00.0.19)
PostJan 15, 2018#1
Anybody has the same problem?
On the new version 18.00.0.17 when you try to edit a long string example: 26 lines which have 540 characters per line, see screenshot.
If you scroll to the right, you will see, starting column 300++ will be "empty".
However, as soon as you click using your mouse on that position 301++, the display screen will be updated and the column 300++ will magically appear.
Reinstalling UltraEdit does not fix the problem.
PS: Work around is to use word wrapper.
PostJan 16, 2018#2
I have the same problem.
Additionally when working on big log files the search function does stop to work after a couples of times.
Will have to find another editor for these things. At the moment it's impossible to work with UltraEdit.
PostJan 16, 2018#3
The new version 18.00.0.19 fix the problem for the long string.
Well, if there is a problem, we can log a case. They are really good to fix the problem.
