I don't have a Mac and therefore don't use UltraEdit for Mac. So I list what I know from UltraEdit for Windows.
In UltraEdit for Windows there are multiple solutions to search for a string and get all lines containing this string into a new file.
There is
Find in Files in
Open files with
Results to Edit window whereby the output format can be customized at
Advanced - Settings or Configuration - Search - Find output format.
The regular
Find dialog has multiple advanced options.
One is
List lines containing string to get all lines containing searched string into a list view with name
Find String List which has the context menu item
Copy to clipboard to copy all lines to clipboard without or with line number and paste them next into a new files or use directly the context menu item
Copy results to new file.
Another advanced
Find option is
Filter lines with
Show to display only the lines containing searched string or
Hide to display only lines not containing the searched string. This feature is mainly used for large LOG and CSV files.
It is also possible to run a regular
Find with
List lines containing string and use in
Find String List view the context menu item
Bookmark all lines and use next command
Copy all bookmarked lines although this does not make much sense as the number of lines to bookmark is limited and the context menu of
Find String List view as the menu items
Copy to clipboard and
Copy results to new file. So there is usually no real need to take the roundabout route via limited number of bookmarks.
Last but not least I wrote UltraEdit scripts to search with a regular expression for strings in a file and write them into a new file, see forum topic
Find strings with a regular expression and output them to new file.
