I have been unable to find ANY UltraEdit for Mac posts anywhere that relate to moving an UltraEdit window for which the window frame is off-screen.
UltraEdit is VERY prone to do this on my system, but usually closing and re-starting brings the window back on-screen (not convenient at all, but usually works).
It happens whenever I switch to multiple monitors or away from multiple monitors.
Here is a workaround, once the issue happens, that doesn't involve closing the application:
Get any corner that is visible, and expand the size of the window.
Then, on the same corner, hold down [option] while shrinking the window, which keeps the aspect ratio.
Repeat as necessary until the window frame (the part of a Mac OS window with the red, yellow, and green dots) comes into view.
Drag the window to the right screen and re-size as desired.
It is VERY frustrating to see almost no help at all online provided by IDM that doesn't immediately provide Windows-only help and tips in response to any query.
Could we make a Mac OS keyword to avoid Windows-only support?
A separate Wiki?
A question, should the menu for UltraEdit for Mac show a "Window" item? The only thing close I have is "View".
I hope this is helpful to anyone who was unaware of a workaround. Mac OS is my 'second language', so it was not intuitive for me.
A separate Wiki?
