Broken Column Mode - Wiping Rows by Autocomplete
8
PostSep 27, 2021#1
The column mode does not work properly when I try to enter parentheses or quotes. Example: I have a html snippet and I want to add print("  to start of each line. I mark all the lines using "Column mode" and start typing. As long as I type "print", it works as expected - the characters appear in all selected rows. As soon as I type either ( or " , Ultraedit tries to autocomplete the ) or " by deleting all rows except for the last one. This makes the column mode unusable.
Note: I have Ultraedit for Mac, version 21.00.0.12
PostSep 27, 2021#2
This is a user to user forum. Please report such issues by email to IDM support or using the technical support form.
It is most likely best for you in the meantime until this issue is fixed and a new version is released to disable the brace and string auto-completion.
8
PostSep 27, 2021#3
OK, done.
