Export and import UE settings including FTP accounts
PostJan 06, 2024#1
Hello
I use UE v2022.0.0.19 on a MAC OS Sonoma. There I have done all configuration in UE and added FTP accounts.
Now I want to use UE on a MACBook Sonoma. To avoid to do all the configuration work and setting up all FTP accounts again, I want to export everything from MAC computer and import it on MACBook.
Unfortunately I can't find such export/import function in the menus.
Is there a way to do export and import of all settings?
6,823625
PostJan 06, 2024#2
I don't have a Mac and therefore do not use UltraEdit for Mac but according to How to restore position of File Tree View in UltraEdit on Mac? open the directory ~/Library/Application Support/UltraEdit being by default hidden containing all the settings files and copy them all with all subdirectories to the MacBook Sonoma.
PostJan 06, 2024#3
Works perfectly fine. Thanks a lot.
