Hello
I use UltraEdit to open remote CSS files. After opening a file, I do a change, open the web browser and check if it works, and switch back to the file and so on.
The file is write protected after just very few changes (and saving the file). Please see screenshot. So I need to click the gray write protected button in the lower right side to be able to continue work.
This makes working almost impossible and is annoying.
Is there a way to stop UltraEdit from setting the file to write protected?
Thanks a lot.
UE 2022.0.0.19 MAC OS
Thanks a lot.
- Write protected indication in the status bar
