You have described that highlighting behavior of a replace all executed on a selection
here and I wrote a reply which is explaining that as a designed behavior in all versions of UltraEdit on Windows, Mac and Linux. The text replaced in the selection is highlighted, but this highlighting disappears or should disappear on next action which results in canceling the selection and also the highlighting of the replaced text inside the selection.
The highlighting of the replaced text in the selection has nothing to do with the
Use persistent highlight all feature of the
Find (UE for Windows) respectively
Search (UE for Mac) command although using internally that feature for highlighting the text replaced in the selection.
Well, I can see in your recorded video that you try to create a new selection with the mouse after the execution of replace all on selected text and that does not work until executing the command
Highlight All Selected by a click on its menu item in menu
View displayed in the menu as being currently enabled. That is indeed a wrong behavior (issue rated by me as bug) of UltraEdit for Mac which should be reported by email to support of UltraEdit, Inc. While the menu item
Highlight All Selected is toggled on after doing a replace all on selected text also in UltraEdit for Windows, there can be simply created a new selection with the pointing device or with the keyboard or just moved the caret to discard the current selection and the highlighting of the replaced text in the selection. It does not matter in UltraEdit for Windows if the setting
Use persistent highlight all is checked or unchecked in the configuration at
Search - Advanced. The selection and the highlighting of the replaced text after the execution of a replace all on a selection is discarded automatically by UltraEdit for Windows on creating a new selection with whatever method or just moving the caret. That should be the behavior of UltraEdit for Mac too.
The setting
Highlight all items found in the configuration respectively preferences is in UltraEdit for Windows at
Search - Auto reset settings in the group
Automatically turn off option after a search operation. If that configuration is checked and a
Search is executed with checked advanced search option
Highlight all items found and later a new
Search should be done resulting in opening the
Search dialog window again, the advanced search option
Highlight all items found is automatically unchecked now on opening the dialog window. The advanced search option
Highlight all items found is checked otherwise on each opening of the
Search dialog window after being once checked by the user with the configuration setting
Highlight all items found not checked in preferences until the user explicitly unchecks the search option
Highlight all items found oneself.
