The installer of UltraEdit does definitely not change any file association. I can guarantee that.
Prior to version 20.00 of UltraEdit a window was displayed on first start of UltraEdit after installation or after an upgrade (not after updating to a newer hotfix version) giving the user the possibility to quickly select file extensions to associate UltraEdit with. This quick file association dialog was removed by IDM in UE v20.00. I suppose the reason was that many users selected in this dialog .htm, .html, .php, .bat, ... as wanting to edit files with such a file extension with UltraEdit, but not knowing about the disadvantages of making UltraEdit the default application for
opening those files.
Additionally there was
Check and show file associations on startup in configuration which when checked resulted in showing the quick file associations configuration dialog window again on next start of UltraEdit. This configuration option was removed in UE v21.00.
So now file associations with UltraEdit can be done only manually by the user via
Advanced - Configuration - File Associations. The installer of UltraEdit does whether add nor remove file associations made by the user with UltraEdit or with Windows Explorer.
It is long time ago that I have changed file associations with UltraEdit and therefore made a test because of this topic.
I made a file association for
.htm with UltraEdit v21.10.0.1032 at
Advanced - Configuration - File Associations by selecting
.htm from the list, entering as file description
HTML File and clicking on the buttons
Add and
OK on Windows 7 x64.
This action resulted in following changes in Windows registry.
Added to registry by UltraEdit:
[HKEY_CURRENT_USER\Software\Classes\.htm]
@="UltraEdit.htm"
[HKEY_CURRENT_USER\Software\Classes\.htm\OpenWithProgIDs]
"UltraEdit.htm"=""
[HKEY_CURRENT_USER\Software\Classes\UltraEdit.htm]
@="HTML File"
[HKEY_CURRENT_USER\Software\Classes\UltraEdit.htm\shell]
[HKEY_CURRENT_USER\Software\Classes\UltraEdit.htm\shell\Open]
[HKEY_CURRENT_USER\Software\Classes\UltraEdit.htm\shell\Open\Command]
@="\"C:\\Program Files (x86)\\IDM Computer Solutions\\UltraEdit\\uedit32.exe\" \"%1\""
[HKEY_CURRENT_USER\Software\Classes\UltraEdit.htm\shell\Print]
[HKEY_CURRENT_USER\Software\Classes\UltraEdit.htm\shell\Print\Command]
@="\"C:\\Program Files (x86)\\IDM Computer Solutions\\UltraEdit\\uedit32.exe\" /p \"%1\""
Added and changed by Windows Explorer:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.htm\UserChoice]
"Progid"="UltraEdit.htm"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\explorer]
"GlobalAssocChangedCounter"=dword:00000097
The counter was increased by 1.
Next I opened again
Advanced - Configuration - File Associations in UltraEdit, selected
.htm from the list and clicked on the buttons
Delete and
OK.
The following key was removed from registry completely:
The value of the default string of key
was changed to an empty string. And of course the
GlobalAssocChangedCounter was increased again by 1.
Conclusion:
The action
Add does not result anymore in storing the current default string value of the changed file association under key
UltraEdit.htm on Windows 7, at least when there is no user account related file association present in Windows registry. It looks like UltraEdit should additionally remember under key
UltraEdit.htm if a file association exists already under key
HKCU\Software\Classes or not.
The action
Delete does not result anymore in restoring the previous default string value of the changed file association from key
UltraEdit.htm respectively deletion of the file association under key
HKCU\Software\Classes if that key was not present on adding the file association. And the key
UltraEdit.htm is not removed from registry.
The added string value
UltraEdit.htm under
OpenWithProgIDs is added by Windows Explorer automatically and not by UltraEdit and therefore UltraEdit should not remove it. It is possible that
UltraEdit.htm remains intentionally because of this string although I don't think so.
But not saving and restoring the current default string value respectively remembering existence of a current user file association and complete deletion if not existing before adding the file association is not good as it requires a manual correction of the file association by the user like when the file association was done outside UltraEdit with Windows Explorer.
I will report my observations on add/delete of a file association with UltraEdit on Windows Vista / 7 / 8 / 8.1 to IDM.
What I have to find out is in which version of UltraEdit the file associations changed from
HKLM\Software\Classes (=HKCR) to
HKCU\Software\Classes. Changing the file associations under HKCU is better as it does not require administrator privileges and the file association is changed only for the current user and not all users using the computer.
The existence of string value
UltraEdit.htm for
HKEY_CLASSES_ROOT\.htm is an indicator that the file assocation was made most likely with an older version of UltraEdit.
There is no problem with file association addition and deletion on Windows XP using UE v21.10.0.1032 with a user account with administrator privileges. UltraEdit changes on Windows XP the file assocation on
HKLM\Software\Classes.
