Toolbar Button to Show/Hide Document Map
    Jul 04, 2015#1
    Has anyone been able to customize the UltraEdit toolbar to show or hide the document map? I see the menu command under View > View/Lists, but I can't find a button when I try to customize the toolbar.
    Thanks!
    Tutto Termino in Giudizio
      Jul 05, 2015#2
      When you move mouse pointer over View - Views/Lists - Document Map in English UE, you can see on left side of status bar at bottom of UltraEdit main window the command help (prompt) Show or Hide Document Map. That's the string for this command in Toolbar Configuration dialog.
      Open Toolbar Configuration dialog, click into Commands list and type quickly show and first command starting with this word is selected in the list. Some lines below there is also Show or Hide Document Map.
      By default this command is already in the MAIN toolbar. It is the last but one command in the MAIN toolbar and therefore cannot be found in the commands list.
        Jul 05, 2015#3
        @Mofi, that worked, thanks!
