How to change the paths of the script files added to script list?
74
Advanced UserAdvanced User
74
PostAug 02, 2021#1
I just migrated my scripts to a new path. Which file do I need to modify to change the directory paths of the script files for the Script list menu/window?
Max
6,823625
PostAug 03, 2021#2
The data of the script files are stored in file %APPDATA%\IDMComp\UltraEdit\volatile\ue.vod in section [Scripting] since UltraEdit for Windows v27.00. I recommend to edit this Unicode (UTF-16 LE) encoded file with Windows Notepad while no instance of UltraEdit is running.
74
74
PostAug 03, 2021#3
Thanks Mofi. It worked great!
