UltraEdit 2024.3.0.13 64-bit, just recently upgraded from a years-old version, 24.10.0.35. I just learned about this feature via a hint, but it only seemed to work via the menu. It seems Ctrl+J was assigned to Select Word instead. I take it this is because old default keyboard shortcuts (I don't think I ever set them manually before) were carried over? I was able to reassign Ctrl+J to Join Lines in Settings > Key Mapping.
Incidentally, as far as I've seen, the only noticeable items that did not carry over through the upgrade were the customized commands I had added to the toolbar, like Open from FTP and Revert to Saved. They were all gone and I started over with a default toolbar.
