Keyboard still slow in UE 11.20+2
Robert Graf
    Oct 29, 2005#1
    I've just installed the latest version of UltraEdit 11.20+2 but my keyboard is still slow - only in UltraEdit.
    When I click on a button on my keyboard (and stay on it) - they character(s) will be displayed very slow - the normal standard keyboard preferences I think.
    But I've my personal keyboard settings - repeat a character very fast - and this does not work in UE 11.20 - and I didn't have a problem in 11.10.
    6,687587
      Oct 29, 2005#2
      Please take a look on forum topic CPU usage with version 11.20.
      Maybe also your problem is caused by the HTML toolbar.
      Maybe you have activated the spelling checker at version 11.20 and this causes the heavy CPU usage. I have seen such a dramatic increase of
      CPU usage with MS Word 97, where over 85% of CPU time is used, when automatic spelling checking is active during editing. I have never used the spelling checker feature of UltraEdit (or Word 97), so it's just an idea.
      Robert Graf
      Robert Graf
        Oct 31, 2005#3
        How can I disable the spelling checker in the new preferences. I didn't found anything. - In the menu Configuration / Editor / Spelling checker nothing is enabled (except 'en' - the first line in the dictionary part. (btw: Suggestion mode is 'bad-speller').
        CPU usage is between 70 - 95 % when I type in UE 11.20
        Robert Graf
        Robert Graf
          Oct 31, 2005#4
          Yes - I've found it ...
          It's the HTML toolbar - when I disable the HTML toolbar then the typing works fast (as usual).
