How to disable copying not selected lines
    Mar 09, 2006#1
    Sometimes I inadvertently hit CTRL-C when I mean to hit CTRL-V. This clears out my clipboard buffer and then I have to go copy the text again and paste again. I hate this. Is there a solution?
      Mar 09, 2006#2
      What you're experiencing probably has to do with the "copy/cut current line when no selection is active" option.
      Advanced -> Configuration -> Editor -> Miscellaneous -> Enable copy/cut of current line when no selection is active
      Try disabling/unchecking that option (I have it disabled because I also sometimes hit Ctrl+C when I meant to hit Ctrl+V).
      206
        Mar 09, 2006#3
        Maybe (meaning, not tested):
        Assign this macro to Ctrl+C:
        Clipboard 1
        Assign this macro to Ctrl+1
        Clipboard 1
        When you screwed up a paste, just hit Ctrl+1 to paste your backup of the most recent copy operation.
        If this works, you could use any of the UE clipboards. You might have to dedicate one of them to this function to avoid unanticipated problems.
        Software For Metalworking
          Mar 09, 2006#4
          scallanh wrote:Advanced -> Configuration -> Editor -> Miscellaneous -> Enable copy/append of current line when no selection is active
          This cures my pain. Thank you. BTW, what functionality did I loose by disabling this?
