Hi!
I'm trying figure out the reason and why it doesnt happend to all the files, that when the text file is big and you have scrolled down to see its end, and then when its been changed by another application and UE asks if I want to reload it, on clicking "yes" it re-loads the changed file and scrolls up to the beginning. It is very annoying when you have to always scroll down to see the changes, for example log files write new information at the end of the file, leaving the current content untouched.
I'd say ok, that how UE works in general, but no, for some unknown reason it doesn't automaticaly scroll up on some files... I cannot say what type of files or anything else at the moment (will try trace it when I can).
So, does anyone know why this happening? Is there a way to prevent UE automaticaly scroll up to the beginning of the file?
