Config Save issue
Config Save issue
    Apr 26, 2006#1
    Using 10.20c version on XP rel2 system. I've been using the editor for years. I had to re-build my system from ground up and have a problem with the configuration settings not being saved. In particular, I check on two features: minimize on last file close and minimize to task bar. It doesn't save those settings when I quit the program. They (upon opening) are then un-checked.
    Where does the program save these attibutes.
    Any help?
    Thanks..
    Rick
    6,685587
      Apr 26, 2006#2
      In uedit32.ini at
      [Settings]
      Minimize on File Close=1
      Minimize to SysTray=1
      Don't ask where is the uedit32.ini - see help of UltraEdit or search in the forum.
