Changing extension case
    May 02, 2006#1
    Is there any way to change the default extension on txt files to lowercase? I know it's silly, but having .TXT at the end annoys me for some reason...
    6,685587
      May 02, 2006#2
      Open Configuration - File Types, select the line with *.TXT, edit TXT to txt, press the Replace button and close the configuration dialog with OK.
        May 02, 2006#3
        Thanks very much. :)
